info("enabledfields")
The info(“enabledfields”) function returns a list of enabled fields in the current database (fields that can be edited).
This function returns a carriage return delimited list of enabled fields in the current database (fields that can be edited). See Disable Editing of Individual Fields to learn more about disabled vs. enabled fields.
Note: To find out what fields are enabled in other open databases, use the dbinfo( function with the enabledfields option.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
