info("proceduredatabase")
The info(“proceduredatabase”) function returns the name of the database that contains the currently running procedure.
This function returns the name of the database that contains the currently running procedure, even if that database is not the currently active database. This can happen when farcall is used to invoke the procedure, or if the procedure is a custom statement.
This example opens the Help Window form in the database that contains the procedure, even if a window from another database is currently on top.
window info("proceduredatabase")+":SECRET"
openform "Help Window"
- loadallprocedures -- loads all the procedures from a dictionary into the current database.
If a procedure doesn't exist it will be created.
