info("unsharedrecordid")
The info(“unsharedrecordid”) function returns the minimum ID for unshared records.
This function returns the minimum ID for unshared records. If a record has an ID greater than this number, it is a summary record. If a record has this exact ID, there was a problem when adding the record to the database and it has not been, and cannot be, added to the server.
- server --
