info("timelimitremaining")
The info(“timelimitremaining”) function returns the amount of time available (in seconds) before a loop will time out.
This function returns the amount of time available (in seconds) before a loop will time out. You can use it with the timelimit function, see Preventing Endless Loops.
- timelimit -- specifies the maximum time a procedure can continue to run after this statement.
