info("availablescreenrectangle")
The info(“availablescreenrectangle”) function returns a rectangle defining the edges of the main screen, after deducting for the space of the menu bar and dock (if visible).
This function returns a rectangle (see Graphic Coordinates) defining the edges of the main screeen (the screen that contains the menu bar). Any area of the screen that is reserved for the operating system (for example the menu bar or the dock) is excluded from the rectangle. The rectangle is in screen relative coordinates.
