info("toolbarvisible")
The info(“toolbarvisible”) function returns true if the current window has a visible tool bar.
This function returns true if the current window has a visible tool bar.
This procedure checks to see if the current window has a toolbar. If so, it simply deletes the current record. If there is no tool bar it asks for confirmation before deleting the record.
if not info("toolbarvisible")
alertnoyes "Are you sure you want to delete?"
if info("dialogtrigger") contains "no" rtn endif
deleterecord
