info("ram")
The info(“ram”) function returns the amount of physical RAM in this computer.
This function returns the amount of physical RAM in this computer (in bytes).
info("ram") ☞ 17179869184
Divide by 1024 cubed to find the RAM size in gigabytes.
info("ram")/(1024*1024*1024) ☞ 16
