info("applicationsupportfolder")
The info(“applicationsupportfolder”) function returns the path to the current user’s Application Support folder (inside the Library folder).
This function returns the path to the current user’s Application Support folder (inside the Library folder)
Note: This function allows language independent access to the Application Support folder, and will correctly locate the folder even if you are using a non-English system.
