info("serverrecordts")
The info(“serverrecordts”) function returns the internal time stamp associated with the current record.
This function returns the internal time stamp associated with the current record. This is used for synchronization in shared databases. If a database is not shared, this number will always be zero.
Note: The value is not actually a chronological time. If one record has a larger time stamp than another database, you know it was modified later, but not how much later.
1.0No Change/Updated/NewCarried over from Panorama 6.0
