The info(“matrixdata”) function returns the data associated with the current matrix object.
This function returns the data associated with the current matrix object. There are two places this function can be used:
1) When drawing the matrix (in a formula in an object that is in the matrix frame).
2) In a procedure that is triggered by clicking on the matrix.
To determine the matrix cell data, Panorama calculates the formula associated with the matrix object.
