info("documentsfolder")
The info(“documentsfolder”) function returns the path to the current user’s Documents folder.
This function returns the path to the current user’s Documents folder.
Note: This function allows language independent access to the Documents folder, and will correctly locate the folder even if you are using a non-English system.
