info("databasefilename")
The info(“databasefilename”) function returns the name of the current database.
This function returns the name of the current database. This function returns the complete file name, including the .pandb extension (if any). If the database has never been saved to disk, this function returns "". This will occur for a new, untitled, database, and also for a Panorama 6 database that has been imported into Panorama X but not yet saved as a Panorama X database.
