info("activesuperobject")
The info(“activesuperobject”) function returns the name of the currently active text editor or word processor object, if any.
This function returns the name of the currently active text editor or word processor object, if any. If no such object is currently being edited, the function returns empty text (""
Note: This function is still available for compatibility with legacy databases, but for new applications you should use the info(“focusobject”) function.
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
10.0 | No Change | Carried over from Panorama 6.0, but now has been replaced by the info("focusobject") function. |
