getproceduretext(
DATABASE
PROCEDURE
The getproceduretext( function gets the contents (source code) of a procedure.
database – is the name of the database that contains the procedure. You can also use "" to specify the current database.
procedure – is the name of the procedure.
This function allows a formula to extract and look at the text (source code) of other procedures. This function is disabled and will return empty text if the user is not authorized to see the contents of the procedure.
