info(
OPTION
The info( function returns miscellaneous bits of information about the system, the current database, the current window, etc.
option – the type of information that you want to retrieve.
This function returns miscellaneous bits of information about the system, the current database, the current window, etc. See the see also section below for detailed information about specific info options.
