info("errorstatement")
The info(“errorstatement”) function returns the name of the statement that Panorama was trying to run at the time an error occurred.
This function can be used in Error Handling code. It returns the name of the statement that Panorama was trying to run at the time an error occurred.
- catcherror( -- evaluates an expression, but suppresses any error generated by that expression.
- error( -- returns an error with the specified message.
- errortext( -- evaluates an expression, but returns only the error message generated (if any).
