info("fieldnumber")
The info(“fieldnumber”) function returns the number of the current field (starting from 1).
This function returns the number of the current field (starting from 1). For example, you could use it to test to see if the current field is the last field of the database.
info("fieldnumber")=info("fieldcount") ☞ true if currently on last field
- field -- tells Panorama to move to the specified field for the current record.
- fieldblueprint -- creates blueprint code for the specified field.
