info("formwindownumbers")
The info(“formwindownumbers”) function returns the unique ID numbers of all open form windows.
This function returns the unique ID numbers of all open form windows. See Window ID Numbers to learn about this topic. This function will return a carriage return delimited text array with all of the form window numbers.
See also the info(“formwindows”) function, which returns the names of all open form windows.
