info("windowname")
The info(“windowname”) function returns the name of the current window.
This function returns the name of the current window.
This example switches to the Appointments database and selects today’s appointments. When this is finished, it switches back to the original window, right back where it started.
local wasWindow
wasWindow=info("windowname")
openfile "Appointments"
select When=today()
window wasWindow
