info("activeobjectid")
The info(“activeobjectid”) function returns the object ID of the currently active text editor or text list object, if any.
This function returns the object ID of the currently active text editor or text list object, if any. If no such object is currently being edited, the function returns zero.
Once you have the object id, you can use the objectinfo( function to find out any property of the object.
