info("moviesfolder")
The info(“moviesfolder”) function returns the path to the current user’s Movies folder.
This function returns the path to the current user’s Movies folder.
Note: This function allows language independent access to the Movies folder, and will correctly locate the folder even if you are using a non-English system.
