info("downloadsfolder")
The info(“downloadsfolder”) function returns the path to the current user’s Downloads folder.
This function returns the path to the current user’s Downloads folder.
Note: This function allows language independent access to the Downloads folder, and will correctly locate the folder even if you are using a non-English system.
