info("focusobjectid")
The info(“focusobjectid”) function returns the object ID of the currently active text editor or text list object, if any.
This function returns the object ID of the currently active text editor or text list object, if any. If no such object is currently being edited, the function returns empty text (“”).
Once you have the object id, you can use the objectinfo( function to find out any property of the object.
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- Matrix Programming -- programming a Matrix object.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Text List Programming -- programming a Text List Object.
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
10.0 | New | Carried over from Panorama 6.0. |
