info("parameters")
The info(“parameters”) function returns the number of parameters passed to a subroutine.
This function returns the number of parameters passed to a subroutine.
This example shows you you can write a subroutine that will add up a list of numbers passed to it.
// SumNumbers
// Usage: call("","SumNumbers",n1,n2,n3, ... ,n999)
local sum
sum=0
for n,1,info("parameters")
sum=sum+parameter(n)
endloop
functionvalue sum
Now this subroutine can be used in any formula to add up a list of numbers.
call("","SumNumbers",12,20,16) ☞ 48
call("","SumNumbers",6,5,4,3,2,1) ☞ 21
- Custom Statements -- creating your own custom statements that can be used in your code.
- parameterentity( -- returns the entity (field or variable) associated with a subroutine parameter, if any.
