info("matrixclickedframeform")
The info(“matrixclickedframeform”) function returns the form that contains the matrix frame, or "" if the current form contains the frame.
This function returns the form that contains the matrix frame, or "" if the current form contains the frame. This function is designed to be used in conjunction with the info(“matrixclickedobjectid”) function.
