info("pagenumber")
The info(“pagenumber”) function returns the current report page number.
This function returns the current report page number. This function is designed to be used in a Text Display object in a report form. This example will print page numbers in the format Page 1 of 7, Page 2 of 7, etc.
"Page "+info("pagenumber")+" of "+info("pagecount")
- Automatic Mailing Label Construction -- creates a mailing label.
- Automatic Report Construction -- creates a tabular report with columns of data.
- info("printer") -- returns the current default printer.
- info("printers") -- returns a list of all available printers.
- pagesetup -- displays the page setup dialog.
- print -- prints the database.
- printonerecord -- prints the the currently active record.
- Report Tile Object -- component for assembling a custom report.
- setreportcolumns -- allows a procedure to control the number of columns of a report, and the direction (across or down).
