The info(“matrixcolumn”) function returns the current column number within a matrix object.
This function returns the current column number within a matrix object. There are two places this function can be used:
1) When drawing the matrix (in a formula in an object that is in the matrix frame).
2) In a procedure that is triggered by clicking on the matrix.
Matrix columns are numbered starting with 1 on the left.
