info("applicationsfolder")
The info(“applicationsfolder”) function returns the path to the current user’s Applications folder.
This function returns the path to the current user’s Application folder.
Note: This function allows language independent access to the Application folder, and will correctly locate the folder even if you are using a non-English system.
