info("defaultmaxdatasheetcolumns")
The info(“defaultmaxdatasheetcolumns”) function default maximum number of allowed data sheet columns.
This function returns the default maximum number of allowed data sheet columns, i.e. the “factory setting.” To get the current setting use the formula:
catcherror(info("defaultmaxdatasheetcolumns"),getpreferencevalue("PXMaxDataSheetColumns"))
