info("windowrectangle")
The info(“windowrectangle”) function returns a rectangle defining the edges of the current window. The rectangle is in screen relative coordinates.
This function returns a rectangle defining the edges of the current window. The rectangle is in screen relative coordinates. For example, you could use this function to remember the current window position so that you could reset it later with the zoomwindowrectangle statement.
