info("globalvariables")
The info(“globalvariables”) function builds a carriage return separated text array containing a list of the currently allocated global variables.
This function builds a carriage return separated text array containing a list of the currently allocated global variables.
- assignglobal( -- assigns a value to a global variable (creating the variable if necessary).
