info("milliseconds")
The info(“milliseconds”) function returns the number of milliseconds (1/1000th second) since the system started up.
This function returns the number of milliseconds (1/1000th second) since the system started up. This function can be used to time intervals smaller than 1 second.
- converttimezone( -- converts a time or superdate from one time zone to another.
- daylightsavingstimeoffset( -- returns the current daylight saving time offset of the specified time zone.
- info("localtimezone") -- returns the local time zone for the current location of your computer.
- info("timezoneabbreviations") -- returns a dictionary of time zone abbreviations supported by the system.
- info("timezones") -- returns a list of time zone regions recognized by the system.
- nextdaylightsavingstimetransition( -- returns the next date on which a transition to or from daylight savings time occurs.
- now( -- returns the current time (number of seconds since midnight).
- regulartime( -- extracts a regular time (seconds since midnight) from a superdate.
- secsminshours( -- this converts a time (number of seconds) into an approximate text value.
- texttimedifference( -- allows time math to be performed on text values.
- texttimeinterval( -- allows time math to be performed on text values.
- time24( -- takes a time and makes sure it falls within a 24 hour period.
- timedifference( -- calculates the difference between two times. It works correctly even if the interval between the two times crosses over midnight.
- timeinterval( -- calculates the time interval between two times. It works correctly even if the interval between the two times crosses over midnight.
- timezoneabbreviation( -- returns the abbreviation of the specified time zone.
- timezonename( -- returns the continent and city of the specified time zone.
10.0 | New | New in this version |
