globalvalue(
The globalvalue( function returns the value of a global variable.
This function makes it possible to access a global variable even if there is a local or fileglobal variable with the same name.
This example dials the phone using the default area code stored as a global variable named DefaultAreaCode.
dial globalvalue("DefaultAreaCode")+Phone
Note: This function also has an alternate name: grabglobalvariable(
- assignglobal( -- assigns a value to a global variable (creating the variable if necessary).
