info("stopped")
The info(“stopped”) function returns true or false depending on the whether the last uprecord, downrecord, left or right statement succeeded or failed.
The info(“stopped”) function returns true or false depending on the result of the last uprecord, downrecord, left or right statement. If the statement could not move the active cell because the active cell was already as far as it could go, the function will return true. Otherwise it will return false.
