info("noshow")
The info(“noshow”) function returns true if noshow is currently turned on, false if it is not.
This function returns true if noshow is currently turned on, false if it is not. This example shows how you can write a procedure that will turn on noshow, perform an operation, then restore noshow back to its original state (where it may have already been turned on).
local  nstate
nstate=info("noshow")
noshow
sortup
if (not nstate)
    endnoshow
