The info(“matrixrow”) function returns the current row number within a matrix object.
This function returns the current row number within a matrix object. There are two places this function can be used:
1) When drawing the matrix (in a formula in an object that is in the matrix frame).
2) In a procedure that is triggered by clicking on the matrix.
Matrix rows are numbered starting with 1 on the top.
