info("publicfolder")
The info(“publicfolder”) function returns the path to the current user’s Public folder.
This function returns the path to the current user’s Public folder. You can save files that you want to share with other users on the system in this folder.
Note: This function allows language independent access to the Public folder, and will correctly locate the folder even if you are using a non-English system.
- info("matrixseparator") -- function returns the separator associated with  the current matrix.
