info("volumes")
The info(“volumes”) function returns a list of all of the currently mounted volumes (disks) on the computer.
The info(“volumes”) function returns a carriage return separated array listing all of the currently mounted volumes (disks) on the computer. The startup (boot) volume is always listed as the first element of this array.
