info("eof")
The info(“eof”) function returns true if the active record is currently the last visible (selected) record.
The info(“eof”) function returns true if the active record is currently the last visible (selected) record. (Note: eof stands for end of file.)
This example loops until the database is at the very last visible record.
loopwhile not info("eof")
    downrecord
endloop
- field -- tells Panorama to move to the specified field for the current record.
