longtimestr(
THETIME
The longtimestr( function converts a number to text in am/pm time format, including seconds.
thetime – number of seconds since midnight (see the time( and now( functions).
This function converts a number to text in am/pm time format, including seconds.
longtimestr(now()) ☞ 6:44:08 PM
timepattern(thetime,"hh:mm:ss am/pm")
- converttimezone( -- converts a time or superdate from one time zone to another.
- daylightsavingstimeoffset( -- returns the current daylight saving time offset of the specified time zone.
- info("localtimezone") -- returns the local time zone for the current location of your computer.
- info("timezoneabbreviations") -- returns a dictionary of time zone abbreviations supported by the system.
- info("timezones") -- returns a list of time zone regions recognized by the system.
- nextdaylightsavingstimetransition( -- returns the next date on which a transition to or from daylight savings time occurs.
- now( -- returns the current time (number of seconds since midnight).
- regulartime( -- extracts a regular time (seconds since midnight) from a superdate.
- secsminshours( -- this converts a time (number of seconds) into an approximate text value.
- texttimedifference( -- allows time math to be performed on text values.
- texttimeinterval( -- allows time math to be performed on text values.
- time24( -- takes a time and makes sure it falls within a 24 hour period.
- timedifference( -- calculates the difference between two times. It works correctly even if the interval between the two times crosses over midnight.
- timeinterval( -- calculates the time interval between two times. It works correctly even if the interval between the two times crosses over midnight.
- timezoneabbreviation( -- returns the abbreviation of the specified time zone.
- timezonename( -- returns the continent and city of the specified time zone.
