regulartime(
SUPERDATE
The regulartime( function extracts a regular time (seconds since midnight) from a superdate.
superdate – is a number that combines the date and time into a single value. See the superdate( function.
The regulartime( function extracts a regular time (seconds since midnight) from a superdate. SuperDates combine the date and time into a single number - the number of seconds since January 1, 1904. SuperDates make it easy to calculate time intervals across multiple days. However, SuperDates take up more storage than regular dates, and are not as easy to work with. In addition, SuperDates are limited to dates after 1904 AD.
In its heyday, the Santa Fe Super Chief train would travel between Chicago and Los Angeles in 39 and 1/2 hours. This example uses SuperDates to calculate the arrival time and day when the user enters the departure time.
local Arrival,Departure,xTime
xTime="7:30 pm"
gettext "Departure Time",xTime
Departure=superdate(today(),time(xTime))
Arrival=Departure+superdate(0,time("39:30:00"))
message "Arrives "+datepattern(regulardate(Arrival),"DayOfWeek")+
" at "+timepattern(regulartime(Arrival),"hh:mm am/pm")
If the train leaves at 7:30 pm on Monday, the message will be Arrives Wednesday at 11:00 am. As you can see, SuperDate arithmetic is very easy, just add or subtract. There’s no need to worry about crossing midnight, because that simply is the start of a new day.
- converttimezone( -- converts a time or superdate from one time zone to another.
- daylightsavingstimeoffset( -- returns the current daylight saving time offset of the specified time zone.
- fixsuperdates -- fixes Panorama 6 SuperDates in current field.
- info("localtimezone") -- returns the local time zone for the current location of your computer.
- info("timezoneabbreviations") -- returns a dictionary of time zone abbreviations supported by the system.
- info("timezones") -- returns a list of time zone regions recognized by the system.
- nextdaylightsavingstimetransition( -- returns the next date on which a transition to or from daylight savings time occurs.
- now( -- returns the current time (number of seconds since midnight).
- regulardate( -- extracts a regular date (number of days from January 1, 4713 B.C.) from a superdate.
- secsminshours( -- this converts a time (number of seconds) into an approximate text value.
- SuperDates -- date and time combined into a single value.
- superdateunixtime( -- converts a Panorama superdate into a 13 digit UNIX epoch date/time (including milliseconds).
- texttimedifference( -- allows time math to be performed on text values.
- texttimeinterval( -- allows time math to be performed on text values.
- time24( -- takes a time and makes sure it falls within a 24 hour period.
- timedifference( -- calculates the difference between two times. It works correctly even if the interval between the two times crosses over midnight.
- timeinterval( -- calculates the time interval between two times. It works correctly even if the interval between the two times crosses over midnight.
- timezoneabbreviation( -- returns the abbreviation of the specified time zone.
- timezonename( -- returns the continent and city of the specified time zone.
- unixtimesuperdate( -- converts a 13 digit UNIX epoch date/time (including milliseconds) into a Panorama superdate.
