timeinterval(
STARTTIME
ENDTIME
The timeinterval( function calculates the time interval between two times. It works correctly even if the interval between the two times crosses over midnight.
starttime – is a number (number of seconds) representing the starting point of the time interval.
endtime – is a number (number of seconds) representing the ending point of the time interval.
The timeinterval( function calculates the time interval between two times. It works correctly even if the interval between the two times crosses over midnight. This function returns a time interval between 0 and 24 hours. See also the timedifference( function, which returns a time interval between -12 and +12 hours.
If the end time is later in the same day as the start time, the result of the function is the same as subtracting the start time from the end time:
timepattern(timeinterval(time("205a"), time("930p")),"hh:mm") ☞ 19:25
If the end time is in the next day, the function adjusts for the fact that the interval crosses over midnight:
timepattern(timeinterval(time("930p"), time("205a")),"hh:mm") ☞ 4:35
Note: The timeinterval( function assumes that the interval is no more than 24 hours. If you need to compute intervals that cross over multiple days you must use SuperDates, which combine both date and time into a single value.
- converttimezone( -- converts a time or superdate from one time zone to another.
- daylightsavingstimeoffset( -- returns the current daylight saving time offset of the specified time zone.
- info("localtimezone") -- returns the local time zone for the current location of your computer.
- info("timezoneabbreviations") -- returns a dictionary of time zone abbreviations supported by the system.
- info("timezones") -- returns a list of time zone regions recognized by the system.
- nextdaylightsavingstimetransition( -- returns the next date on which a transition to or from daylight savings time occurs.
- now( -- returns the current time (number of seconds since midnight).
- regulartime( -- extracts a regular time (seconds since midnight) from a superdate.
- secsminshours( -- this converts a time (number of seconds) into an approximate text value.
- texttimedifference( -- allows time math to be performed on text values.
- texttimeinterval( -- allows time math to be performed on text values.
- time24( -- takes a time and makes sure it falls within a 24 hour period.
- timedifference( -- calculates the difference between two times. It works correctly even if the interval between the two times crosses over midnight.
- timezoneabbreviation( -- returns the abbreviation of the specified time zone.
- timezonename( -- returns the continent and city of the specified time zone.
