superdatestr(
SUPERDATE
The superdatestr( function converts a number containing a superdate (date + time) to text.
superdate – is a number that combines the date and time into a single value. See the superdate( function.
This function converts a number containing a superdate to text.
superdatestr(supernow()) ☞ 9/5/13 6:46 PM
Superdates combine a date and time into a single value. See superdate( for more information.
datepattern(regulardate(superdate),"mm/dd/yy")+" "+timepattern(regulartime(superdate),"hh:mm am/pm")
- calendardate( -- helps in creating monthly calendars.
- calendarday( -- helps in creating monthly calendars.
- converttimezone( -- converts a time or superdate from one time zone to another.
- datevalue( -- converts integer values for year, month and day into a number representing a date.
- daylightsavingstimeoffset( -- returns the current daylight saving time offset of the specified time zone.
- dayofmonth( -- computes the day within a month.
- dayofquarter( -- computes the day within a quarter.
- dayofweek( -- computes the day of the week, with Sunday being 0, Monday 1, etc.
- dayofyear( -- computes the day within a quarter.
- dayvalue( -- extracts the day from a date as a numeric value.
- firstdayofweek( -- returns the user's preference for first day of the week.
- info("localtimezone") -- returns the local time zone for the current location of your computer.
- info("timezoneabbreviations") -- returns a dictionary of time zone abbreviations supported by the system.
- info("timezones") -- returns a list of time zone regions recognized by the system.
- month1st( -- computes the first day of a month.
- monthlength( -- computes the length (number of days) of a month.
- monthmath( -- takes a date and computes the date that is one or more months before or after the original date.
- monthvalue( -- extracts the month from a date as a numeric value.
- nextdaylightsavingstimetransition( -- returns the next date on which a transition to or from daylight savings time occurs.
- now( -- returns the current time (number of seconds since midnight).
- quarter1st( -- computes the first day of a quarter.
- quartervalue( -- extracts the quarter from a date as a numeric value.
- regulardate( -- extracts a regular date (number of days from January 1, 4713 B.C.) from a superdate.
- regulartime( -- extracts a regular time (seconds since midnight) from a superdate.
- secsminshours( -- this converts a time (number of seconds) into an approximate text value.
- texttimedifference( -- allows time math to be performed on text values.
- texttimeinterval( -- allows time math to be performed on text values.
- time24( -- takes a time and makes sure it falls within a 24 hour period.
- timedifference( -- calculates the difference between two times. It works correctly even if the interval between the two times crosses over midnight.
- timeinterval( -- calculates the time interval between two times. It works correctly even if the interval between the two times crosses over midnight.
- timezoneabbreviation( -- returns the abbreviation of the specified time zone.
- timezonename( -- returns the continent and city of the specified time zone.
- today( -- returns a number corresponding to today's date.
- week1st( -- computes the first day of a week (Sunday).
- weekvalue( -- extracts the week from a date as a numeric value.
- year1st( -- computes the first day of a year.
- yearvalue( -- extracts the year from a date as a numeric value.
