texttimedifference(
START
END
The texttimedifference( function allows time math to be performed on text values.
start – The starting point of the time interval.
end – The ending point of the time interval.
This function allows time math to be performed on text values (use the timedifference( function when working with numeric time values). The parameters and result are all text.
texttimedifference("9:45 AM","12:20 PM") ☞ 2:35:00
texttimedifference("2:10:37 PM","7:50:09 PM") ☞ 5:39:32
texttimedifference("2:10:37 PM","7:50:09 AM") ☞ -6:20:28
If you need to calculate the difference between two times that cross midnight, use the texttimeinterval( function. If you need to calculate time differences across multiple days, use SuperDates (see superdate().
timepattern(timedifference(time(start),time(end)),"hh:mm:ss")
- converttimezone( -- converts a time or superdate from one time zone to another.
- daylightsavingstimeoffset( -- returns the current daylight saving time offset of the specified time zone.
- info("localtimezone") -- returns the local time zone for the current location of your computer.
- info("timezoneabbreviations") -- returns a dictionary of time zone abbreviations supported by the system.
- info("timezones") -- returns a list of time zone regions recognized by the system.
- nextdaylightsavingstimetransition( -- returns the next date on which a transition to or from daylight savings time occurs.
- now( -- returns the current time (number of seconds since midnight).
- regulartime( -- extracts a regular time (seconds since midnight) from a superdate.
- secsminshours( -- this converts a time (number of seconds) into an approximate text value.
- texttimeinterval( -- allows time math to be performed on text values.
- time24( -- takes a time and makes sure it falls within a 24 hour period.
- timedifference( -- calculates the difference between two times. It works correctly even if the interval between the two times crosses over midnight.
- timeinterval( -- calculates the time interval between two times. It works correctly even if the interval between the two times crosses over midnight.
- timezoneabbreviation( -- returns the abbreviation of the specified time zone.
- timezonename( -- returns the continent and city of the specified time zone.
