texttimeinterval(
START
END
The texttimeinterval( function allows time math to be performed on text values.
start – The starting point of the time interval.
end – The ending point of the time interval.
This function allows time math to be performed on text values. The parameters and result are all text. This function can calculate time intervals that cross midnight.
texttimeinterval("9:45 PM","1:12 AM") ☞ 3:27:00
texttimeinterval("2:10:37 PM","7:50:09 PM") ☞ 5:39:32
texttimeinterval("2:10:37 PM","7:50:09 AM") ☞ 17:39:32
If you need to calculate time differences across multiple days, use SuperDates (see superdate().
timepattern(timeinterval(time(start),time(end)),"hh:mm:ss")
