Numeric data can be stored in either integer or floating point format.
Use the integer data type when you want to store whole numbers. Here are some examples of integer values:
2
98
-326
42891
Panorama X stores integers in 64 bit format, which means that any integer value between -9,223,372,036,854,775,808 and +9,223,372,036,854,775,807 can be stored. (Panorama 6 and earlier versions used 32 bit format, which was much more limited.)
Use the floating point data type when you need to store real numbers – numbers with a fractional component. Here are some examples of floating point values.
1.5
3.14159
-8.1893047e12
39129.74
Panorama X stores floating point values in IEEE 64 bit format, which means that values approximately between -10308 to 10308 can be stored, with approximately 16 significant digits. For detailed technical information about this format see double precision floating point.
Legacy versions of Panorama (version 6 and earlier) had several “fixed point” formats. These formats could store a limited range of real numbers with limited precision. Many years ago, fixed point numbers had a performance advantage over floating point numbers, but this is no longer the case. Since the limited precision of fixed point numbers could cause calculation errors, fixed point formats are no longer used. When a database is converted from Panorama 6 to Panorama X, all fixed point data fields are converted to floating point format.
Internally, Panorama stores numbers in a pure binary form. But when a number is displayed or printed, it is converted to text so that you can read it. This conversion can take different forms, for example the number 1234 could be formatted many ways, some of which are shown here:
1234
1,234
1,234.00
1.234e3
By default, Panorama will pick the simplest format, but you can explicitly control how numbers are formatted by using a Numeric Pattern. See Numeric Patterns to learn all the details.
10.0 | Updated | Carried over from Panorama 6.0, but fixed point numbers are no longer supported (use floating point instead). |
