To move a field to a new position within the data sheet, simply drag the field name to the new position. (Note: You must make sure that all fields are visible before rearranging fields this way.)
Of course you can Undo to move the field back to its original position (or simply drag it back).
Another way to rearrange field order is to open the Reorder Fields dialog from the Field menu. This dialog lists all of the fields in the database, including fields that are currently invisible.
To change the field order, drag the fields within the list, then press the Reorder Fields button.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
10.2 | Updated | New Reorder Fields dialog. |
