emptydatabase(
The emptydatabase( function returns true if the current database is completely blank.
This function returns true if the current database is completely blank. In other words, it returns true if there is only one record and that record is entirely blank.
emptydatabase() ☞
arraystrip(exportline(),chr(9))=""
