The Blueprint dialog sheet allows you to view and modify the raw specifications of the current field. Usually you would use the property panels for this (see Field Properties Panel), but the blueprint allows you to directly access the “source code” for any field. Choose Field Blueprint from the Field menu to open this dialog.
Here’s the Blueprint dialog sheet in action to change the alignment of the current field.
Of course usually it is easier to simply use the Field Properties Panel, but the blueprint does allow you to quickly see and potentially modify all field attributes.
An excellent use for the Field Blueprint Dialog is to take a field in one database and make an exact clone of it in another database, as is shown in this movie. This is done by using copy and paste to transfer the entire blueprint to the second field.
The text in the dialog is actually program code, so you can also copy it directly into a procedure.
To learn about specific field properties see Field Properties.
- automaticfieldname( -- returns an available field name.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
