emptyline(
The emptyline( function returns true if the entire current record (all fields) is blank, otherwise it is false.
This function returns true if the entire line (all fields) are blank, otherwise it is false.
emptyline() ☞ 0
For example you could select all totally empty records using the statement
select emptyline()=true()
arraystrip(exportline(),chr(9))=""
